Double MCU failure/errors and failed print
Printer Model: 2 ender 3 printers with instances
MCU / Printerboard: Btt pad 7 running two printers 4.2.2 & 4.2.7
klippy_E235.log (4.6 MB)
klippy_E400.log (4.6 MB)
I had both printers finally running perfectly. Today i powered on the printers and started getting the errors below on both printers.
Could not connect to the fluidd web interface either. reset and rebooted and that took care of the problems. I then started a print on E235 and it failed about 1 hour in. After that both printers have been flashing the same errors. I am stumped. i havent touched the config in a couple days! attatched both printer klippy’s
Failed automated reset of MCU ‘rpi’
Error configuring printer
Lost communication with MCU ‘rpi’
Printer is shutdown
In both cases the issue is:
b'Got EOF when reading from device'
Thank you for the response! bummer! sounds like more senseless tinkering instead of printing. I’ve been at this for just shy of 2 weeks upgrading 3 printers to klipper after years of marlin headaches. hoping this isn’t a reoccurring thing with klipper as well.
