Klipper Shutdown When Moving Manual Stepper Simultaneously
Printer Model: Voron Trident
MCU / Printerboard: BTT-SKR 1.4 & MELLOW Fly D8
Host / SBC: Orange Pi Zero 3
So i tried to make pico mmu (Pico MMU · lhndo/LH-Stinger Wiki · GitHub ) but when i comfigure my [manual_stepper] there is something wrong with it. when i move my stepper this message show up.
strange thing is, this message is only appear when i execute the macro/gcode command when stepper is moving. but when is stop and execute it. it works fine the stepper is moving correctly
klippy.log (5).zip (6.4 MB)
Hi @zapprint ,
It looks like you’re getting an internal error on stepcompress, which is one of the more obscure errors. :thinking:
Have you seen Happy Hare MMU software? It has Pico MMU support and is much more robust than simple macros.
Git version: 'v0.13.0-212-g78462cff4-dirty'
Untracked files: klippy/extras/led_effect.py, klippy/extras/z_calibration.py
Branch: master
Remote: origin
b'stepcompress o=2 i=0 c=4 a=0: Invalid sequence'
Internal error on command:"MANUAL_STEPPER"
  File "/home/zopi/klipper/klippy/gcode.py", line 212, in _process_commands
    handler(gcmd)
  File "/home/zopi/klipper/klippy/gcode.py", line 140, in <lambda>
    func = lambda params: origfunc(self._get_extended_params(params))
  File "/home/zopi/klipper/klippy/gcode.py", line 150, in <lambda>
    handler = lambda gcmd: self._cmd_mux(cmd, gcmd)
  File "/home/zopi/klipper/klippy/gcode.py", line 315, in _cmd_mux
    values[key_param](gcmd)
  File "/home/zopi/klipper/klippy/extras/manual_stepper.py", line 120, in cmd_MANUAL_STEPPER
    self.do_move(movepos, speed, accel, sync)
  File "/home/zopi/klipper/klippy/extras/manual_stepper.py", line 81, in do_move
    self.sync_print_time()
  File "/home/zopi/klipper/klippy/extras/manual_stepper.py", line 47, in sync_print_time
    toolhead.dwell(self.next_cmd_time - print_time)
  File "/home/zopi/klipper/klippy/toolhead.py", line 463, in dwell
    self._advance_move_time(next_print_time)
  File "/home/zopi/klipper/klippy/toolhead.py", line 291, in _advance_move_time
    self._advance_flush_time(flush_time)
  File "/home/zopi/klipper/klippy/toolhead.py", line 278, in _advance_flush_time
    self.motion_queuing.flush_motion_queues(flush_time, sg_flush_time)
  File "/home/zopi/klipper/klippy/extras/motion_queuing.py", line 65, in flush_motion_queues
    raise mcu.error("Internal error in MCU '%s' stepcompress"
mcu.error: Internal error in MCU 'btt-skr' stepcompress
Transition to shutdown state: Internal error on command:"MANUAL_STEPPER"
Hmmm…
@zapprint, can you maybe show the minimal G-code sequence to reproduce that?
It can be related to recent refactoring, so you can also try switching to an older Klipper:
git checkout 3ef760c18
sudo systemctl restart klipper
So, if you can reproduce on the recent release and can’t with the older one, something has been broken recently.
Thanks.
@3dcoded, jfyi, generally, there is an assumption that you should not be able to crash vanilla Klipper, even by the macros.
This is not so obscure, in a sense. This means that, for some reason, itersolve generates steps with a 0 interval (infinite speed), or the stepcompress code does something strange and outputs that sequence.
yeah i found out this is a problem with the klipper. i tried to roll back and it works
cd ~/klipper
sudo systemctl stop klipper
git reset --hard 17ce45d2
sudo systemctl start klipper
@koconnor JFYI,
I will try to make a fix, but it will take some time.
gcode, rp2040 printer.cfg, rp2040 kconfig just in case
Archive.zip (2.0 KB)
python3 klippy/klippy.py rp2040_printer.cfg -a /tmp/klippy_uds -i /tmp/bug.gcode -d out/klipper.dict -o test.serial
INFO:root:Starting Klippy...
INFO:root:Start printer at Wed Aug 20 20:12:39 2025 (1755713559.9 9055.3)
INFO:root:Extruder max_extrude_ratio=2.494510
INFO:root:Loaded MCU 'mcu' 134 commands (v0.13.0-237-gc4ac6e04c / gcc: (Arch Repository) 14.2.0 binutils: (GNU Binutils) 2.43)
MCU 'mcu' config: ADC_MAX=4095 BUS_PINS_i2c0a=gpio0,gpio1 BUS_PINS_i2c0b=gpio4,gpio5 BUS_PINS_i2c0c=gpio8,gpio9 BUS_PINS_i2c0d=gpio12,gpio13 ... BUS_PINS_spi1a=gpio8,gpio11,gpio10 BUS_PINS_spi1b=gpio12,gpio15,gpio14 BUS_PINS_spi1c=gpio24,gpio27,gpio26 CLOCK_FREQ=12000000 MCU=rp2040 PWM_MAX=255 STATS_SUMSQ_BASE=256 STEPPER_OPTIMIZED_EDGE=2 STEPPER_STEP_BOTH_EDGE=1
INFO:root:Sending MCU 'mcu' printer configuration...
INFO:root:Configured MCU 'mcu' (500 moves)
ERROR:root:b'stepcompress o=2 i=0 c=17 a=0: Invalid sequence'
ERROR:root:Internal error on command:"MANUAL_STEPPER"
  File "/home/nefelim4ag/Coding/klipper/klippy/gcode.py", line 212, in _process_commands
    handler(gcmd)
  File "/home/nefelim4ag/Coding/klipper/klippy/gcode.py", line 140, in <lambda>
  File "/home/nefelim4ag/Coding/klipper/klippy/gcode.py", line 150, in <lambda>
  File "/home/nefelim4ag/Coding/klipper/klippy/gcode.py", line 315, in _cmd_mux
  File "/home/nefelim4ag/Coding/klipper/klippy/extras/manual_stepper.py", line 120, in cmd_MANUAL_STEPPER
  File "/home/nefelim4ag/Coding/klipper/klippy/extras/manual_stepper.py", line 81, in do_move
  File "/home/nefelim4ag/Coding/klipper/klippy/extras/manual_stepper.py", line 47, in sync_print_time
  File "/home/nefelim4ag/Coding/klipper/klippy/toolhead.py", line 462, in dwell
  File "/home/nefelim4ag/Coding/klipper/klippy/toolhead.py", line 290, in _advance_move_time
  File "/home/nefelim4ag/Coding/klipper/klippy/toolhead.py", line 279, in _advance_flush_time
    self.motion_queuing.flush_motion_queues(flush_time, sg_flush_time,
                                            trapq_free_time)
  File "/home/nefelim4ag/Coding/klipper/klippy/extras/motion_queuing.py", line 67, in flush_motion_queues
                    % (mcu.get_name(),))
mcu.error: Internal error in MCU 'mcu' stepcompress
ERROR:root:Transition to shutdown state: Internal error on command:"MANUAL_STEPPER"
INFO:root:Dumping gcode input 1 blocks
Read 9055.314311: 'MANUAL_STEPPER STEPPER=sp_motor MOVE=300 SPEED=10 ACCEL=2000\nMANUAL_STEPPER STEPPER=sp_motor MOVE=100 SPEED=10 ACCEL=2000\n'
INFO:root:gcode state: absolute_coord=True absolute_extrude=True base_position=[0.0, 0.0, 0.0, 0.0] last_position=[0.0, 0.0, 0.0, 0.0] homing_position=[0.0, 0.0, 0.0, 0.0] speed_factor=0.016666666666666666 extrude_factor=1.0 speed=25.0
INFO:root:Reactor garbage collection: (0.0, 0.0, 0.0)
Printer is shutdown
WARNING:root:Internal error on command:"MANUAL_STEPPER"
JFYI,
Thanks for the ping and the well designed test case. It’s this change in commit 5cbe7d83e that introduces the regression:
@@ -76,8 +75,6 @@ class ManualStepper:
         self.next_cmd_time = self._submit_move(self.next_cmd_time, movepos,
                                                speed, accel)
-        self.trapq_finalize_moves(self.trapq, self.next_cmd_time + 99999.9,
-                                  self.next_cmd_time + 99999.9)
         toolhead = self.printer.lookup_object('toolhead')
         toolhead.note_mcu_movequeue_activity(self.next_cmd_time)
         if sync:
It’s not immediately clear to me why that change breaks the code - I’ll continue to look at it.
I was able to track this down. The issue was actually introduced in commit 9399e738. I have created a PR at Fix flushing bug in manual_stepper by KevinOConnor · Pull Request #7019 · Klipper3d/klipper · GitHub that will hopefully fix the issue.
