Printer Model: voron 2.4
MCU / Printerboard: MKS Monster8 V2.0
So I am having a few problems with my MANUAL_STEPPERs.
I am unable to issue a command like this:
MANUAL_STEPPER STEPPER=selector_stepper MOVE=10 SPEED=5
Nothing seems to happen at all after the first command.
And nothing seems to happen at all after the second command either.
MANUAL_STEPPER STEPPER=selector_stepper SET_POSITION=0
The code I added in the config file to make the stepper motor work is as follows:
[manual_stepper stepper_toolchanger]
step_pin: PD13
dir_pin: !PD12
enable_pin: !PD7
rotation_distance: 1
[tmc2208 manual_stepper stepper_toolchanger]
uart_pin: PD11
run_current: 0.800
stealthchop_threshold: 0.5
I’m confused where the bug is?
I hope someone can answer this question, thank you very much.
