Klipper Kinematics Bug Report
Run the following G-code on a normal machine:
M104 T0 S170
G28
M109 T0 S170
G1 F180 E-1
G1 F3600 X132.959 Z0.2
G1 F3600 X132.955 E0
It will report an error and shut down:
MCU ‘mcu’ shutdown: Stepper too far in past
This generally occurs when the micro-controller has been
requested to step at a rate higher than it is capable of
obtaining.
Printer is shutdown
Is there an expert to help solve this bug?
Could you please provide the information that was requested of you when you first posted:
Printer Model:
MCU / Printerboard:
Nothing will happen without this information. I would suggest that you also include what is your host machine (ie is it a Raspberry Pi?).
I’m curious to know what a “normal machine” is. I didn’t think such an animal existed.
