MCU shutdown because Rescheduled Timer in the past
Printer Model: A1
MCU / Printerboard: Mks V1.4 with pi-Zero
Tried printing it twice but print stops at same point with the error .
klippy.log (4.6 MB)
It looks like your board cannot cope with the requested step rate. The MKS 1.4 is a pretty slow board and not able to generate too many steps at once.
Try reducing microsteps = 32 to 16. Maybe as a start only for the extruder and see if this already is sufficient.
This is the load graph of your board:
The spikes in the MCU load killed your printer and lead to the error message.
