Klipper won't PWM a fan pin
Printer Model: Custom (Modified Gigabot XLT3+)
MCU / Printerboard: BTT EBB SB2209 CAN (RP2040)
Host / SBC: Raspberry Pi 3 B+
klippy_fan_pwm.log (106.8 KB)
Sorry for what is probably a simple issue. I am trying to use a 4-pin fan with the BTT SB2209 CAN (RP2040) board. The board has a connector for this, and GPIO15 is connected (through a 5V buffer) to the PWM pin on the connector.
if I define this pin as a generic output pin, it appears to work properly. I am able to see voltage at that pin with my multimeter, and it varies based on the PWM value given.
[output_pin fan_pwm]
pin: EBBCan:gpio15
pwm: True
However, if I define this as the control pin for a fan, it does not work.
[fan]
pin: EBBCan:gpio15
No matter what I set the fan speed to in the frontend, I see 0V on that pin.
What am I doing wrong? Is there something different about how a PWM signal is generated when the pin is setup for a fan vs as a generic output?
Do you have another [fan] in your cfg? Try [fan_generic].
Thanks for the suggestion. Switching it to a generic fan seems to work:
[fan_generic test_fan]
pin: EBBCan:gpio15
However, this fan is intended to be the part cooling fan, which from my understanding is what the [fan] section is defining. Is there something different about how I need to define the [fan] compared to [fan_generic]?
Edit: Thanks for the help, I figured I was doing something dumb :P. The problem was that I had another [fan] section defined on my other MCU. Removing that section made things work as I expected.
