LDO Leviathan v1.3 won't flash
Printer Model: Voron v2.4
MCU / Printerboard: LDO Leviathan 1.3
Host / SBC Pi4 8GB
I cannot get this MCU to flash klipper from katapult. I’ve double and triple checked the Katapult and Klipper menu config settings. I’ve used three different USB-C cables. Powered the Pi via external PSU. Any ideas what I’m missing?!
Here’s my BASH, if that helps!
`kevin@voron:~/klipper$ python3 ~/katapult/scripts/flashtool.py -f ~/klipper/out/klipper.bin -d /dev/serial/by-id/usb-katapult_stm32h743xx_220045000751333232323930-if00
Connecting to Serial Device /dev/serial/by-id/usb-katapult_stm32h743xx_220045000751333232323930-if00, baud 250000
Detected USB device running Katapult
Detected Klipper binary version v2026.02.00-0-gc70d21ab-dirty-20260219_110219-voron, MCU: stm32h743xx
Attempting to connect to bootloader
Katapult Connected
Software Version: v0.0.1-110-gb0bf421
Protocol Version: 1.1.0
Block Size: 64 bytes
Application Start: 0x8020000
MCU type: stm32h743xx
Flashing ‘/home/kevin/klipper/out/klipper.bin’…
[ERROR:root:Flash Tool Error
File “/home/kevin/katapult/scripts/flashtool.py”, line 429, in send_file
resp = await self.send_command(
File “/home/kevin/katapult/scripts/flashtool.py”, line 407, in send_command
raise FlashError("Error sending command \[%s\] to Device" % (cmdname))
FlashError: Error sending command [SEND_BLOCK] to Device
The above exception was the direct cause of the following exception:
File “/home/kevin/katapult/scripts/flashtool.py”, line 1104, in main
await sock.run()
File “/home/kevin/katapult/scripts/flashtool.py”, line 1078, in run
await flasher.send_file()
File “/home/kevin/katapult/scripts/flashtool.py”, line 433, in send_file
raise FlashError(
FlashError: Flash write
failed, flash address 0x8020000`
Let us see your build settings. Run
cat ~/klipper/.config
And copy the output to the thread.
