Longer LK4 Pro (2019) issues in setting up Biqu Microprobe V2
Printer Model:Longer LK4 2019
MCU / Printerboard:LGT_KIT_V1
Host / SBC Raspberry Pi 4
klippy.log (112.0 KB)
…I have performed the update following the directions according to Biqu. Which is using the Z- endstop pin, and using spare 5 volt connection, for the lack of better terms.. Having said that I have not been able to deploy the probe. I have gone over everything I could find, even tried to some of the BL Touch settings to no avail. I know one of my biggest issues is not knowing the pin outs, seems the pins are named different from what is on the mainboard. Any suggestions or help would be appreciated.
Longer has an “official” printer.cfg on their github. Has pin names for BLtouch and the Z endstop.
I’d start with the BLtouch wiring and only move to the other if problems arise.
Thank you. I will have a look.
So that board is a 32bit board, how ever I did download the 8 bit version. And using ChatGPT. I was able to find a good pinout of the Mega2560 board that had pin designations for multiple boards. So now I am going to go through the process of testing again.
Thanks again
ALL I know is what shows in that .cfg file. I couldn’t find a picture or a pinout. What are the markings on the microcontroller mounted on your board?
It’s entirely possible MY sources are incorrect.
No worries. I am sorry it has taken me so long to get back to you. But between double checking my config, with what Biqu published, and the Mega2560 pinout which actually had the pins for my board. I was able to get my Microprose probe to work properly.
Thanks again
Mike
LK4 Mainboard Pin Schematic.pdf (436.4 KB)
The Mega2560 is not a 32-bit board. It’s a genuine 8-bit board.
I realize this, my LK4 Pro was one of the early versions with the 8bit board. It took me awhile to find the printer.cfg for it, which was the longer lk4 pro 2019 config.
Thank you.
Thank you all for your help and suggestions.
I appreciate the knowledge sharing here. As I still work my way through the process of updating and modifying this printer and my other 2 printers (Anycubic Kobra 3, and Ender 5 Plus), I am sure I will be back on here asking more questions, but not without trying to find the answer first. For my LK4 Pro, it went from a simple update and upgrade, to frustration and now it is getting better again.
But this is the hobby I enjoy as much or more than my other hobbies. The learning curve seems steep at times but I enjoy it.
