Youāre right. I meant M109, of course.
It is clear to me that these Gcodes are waiting. But it is not clear to me why everything is blocked. Apart from an emergency stop, you cannot execute a cancel or an M105 or something similar.
lg Chris
I donāt think this will lead to anything.
I can stop except āwait until temperature is reachedā is nothing.
No temperature query, no interruption, no LEDs control what else do I know what.
Ok, I got it. Itās because thatās the way it is. And you shouldnāt change that because the ancient people have already done it that way.
Maybe I do not understand this discussion, but:
M140: Start heating āin the backgroundā and continue
M104: Start heating and WAIT until temperature is reached before continuing
Same goes for M190 / M109
So what is the issue in using the non-blocking variants?
I think this should be considered a bug. If delayed gcode is scheduled to be run in 5 seconds, but doesnāt run for 20 minutes because TEMPERATURE_WAIT is blocking it, this is a problem.
For example, lets say delayed gcode is used to implement some custom control loop. Now some other gcode that is run (like TEMPERATURE_WAIT) causes this delayed gcode to be blocked. The control loop will stop running and there will be no process control.
I spent a lot of time trying to find a way to override TEMPERATURE_WAIT (as itās the biggest offender), but canāt find any way to do it. There are no while loops, or goto in the gcode macro support that I can find.
I reported this issue on github #5797, but it was marked not on github, so Iāll leave my comments here.
Suppose you want to wait for a temperature without stopping all other delayed gcode from running. How do you do this using the non-blocking variants? I canāt find any way to do this as I see no while loop or goto in the gcode macro support.
Itās not reasonable to expect all gcode to be modified to not use any blocking gcodes in order for delayed gcode execution to not be blocked.
Sorry, but that is a contradiction. You canāt wait and do not stop at the same time.
If you want to go on with your further gcode commands, you may use M104/M140 instead.
Or you put your delicate code stuff in front of the temperature command.
You may share a code snippet of what you are talking about, so we may see clearer.
No, you are taking a limited view of the gcode. You are viewing things as a single thread, which is the problem. Delayed gcode should be viewed as an interrupt or separate thread that is implementing control functions not related to the base gcode program. See my previous comments where I use delayed gcode to implement a custom control loop.
Would you expect the bed temperature PID to stop running if you execute a TEMPERATURE_WAIT on the hot end? Clearly this would be a problem. I personally use delayed gcode to implement a custom control loop for my chamber temperature. I donāt want this control loop to stop running because PRINT_START is waiting for the bed or hot end temperature target to be reached.
Iām not saying Marlin is any different. I also understand the heater PID are in firmware, I was using that as an example.
Delayd gcode to me should be handled like an interrupt. I saw an example somewhere on the Klipper site about a load filament macro using delayed gcode to clear a message to the screen indicating completion after a certain amount of time. If a TEMPERATURE_WAIT were executed after displaying the message, but before clearing it, the message would stay up there for a long time (until the TEMPERATURE_WAIT completed). Clearly this isnāt the desired behavior, and the delayed gcode is not intended to be synchronized with the base gcode program execution.
With delayed gcode being blocked by blocking gcodes, there is no good way to implement custom process control loops. This severely limits the usefulness of gcode macros. I feel Klipper gcode macros could be much more powerful if a second thread were used to execute delayed gcode at the scheduled time. If this isnāt agreeable, then at least goto, or some type of loop until should be added so a version of TEMPERATURE_WAIT could be coded that wouldnāt block delayed gcode.
Are you sure this was inside the gcode command fifo process or another process outside the gcode command handling as an additional Klipper plugin/subroutine.
It was an example in the gcode macro section of the manual. The macro loaded filament, displayed a message on the display, then scheduled delayed gcode to clear the message after a few seconds. Just found the code:
I can see how changing the gcode execution architecture to be multi-threaded would be a major change. A simpler alternative would be as follows:
Recode all blocking gcode to be spin loops of multiple gcode commands (add goto or some type of while loop).
Insert delayed gcode at the head of FIFO when scheduled. Alternatively a 2nd high priority FIFO could be added for delayed gcode.
This solution seems like minimal architectural changes and would prevent delayed gcode from being blocked for long periods of time.
Sorry for putting this reply here, Iām limited to 3 replies, lol.
I want to use delayed gcode to implement a custom process control loop for my chamber temperature. It controls bed fans, with a PID loop and some other delta T algorithms to not adversely affect bed temperature. It works great (keeps chamber within +/-0.1C), except when the delayed gcode gets blocked by blocking gcode like TEMPERATURE_WAIT in PRINT_START.
What I end up doing is setting temps manually using non-blocking gcodes. Then wait until all temp targets are reached before starting a print. The chamber control loop then keeps the chamber temp steady during the print. Itās not as nice as it could be, but it works for now.
If you can think of another way to implement the process control, Iām listening. I tried to find a way to override the blocking TEMPERATURE_WAIT gcodes with spin loops, but that requires goto, or some type of while loop, neither of which I see in klipper.
I run an IDEX printer on Klipper with two independent heaters with their own PID loops.
Those run well.
If you āmiss useā an extruder heater for the heated chamber?
The problem I see there, you need some fake pins for the necessary (not existing ) connections to the extruder driver.
