Delayed Gcode + Temperature Wait
Printer Model: Voron VT300
MCU / Printerboard: Octopus
I have an delayed Gcode setting my Bedfans at a given percentage, after the bed reached the target temp.
Works great in „manual mode“
But in my print start after setting bed temp i call a temperature _wait for my chamber temp and this somehow stops the delayed gcode to do its thing, I’m sure it worked a while ago.
Is there maybe a workaround?
Is this intended?
The temperature wait commands will block further gcode execution until the temperature is reached. That’s the intended behavior.
Is there a good workaround you could think of?
Maybe some sort of while loop?
What is it that you want to happen?
