Hello, I am having issues getting my BLtouch working on my Makergear M2
The following config makes the probe deploy but now the print bed goes down instead of up and therefore not completing the z-homing
step_pin: PC2
dir_pin: PL2
enable_pin: !PA5
rotation_distance: 8
#endstop_pin: ^!PB4
#position_endstop: 200
position_min: -6
position_max: 200
homing_speed: 15
homing_retract_dist: 2.0
uch]
sensor_pin: ^PB4
control_pin: PA0
x_offset: 31
y_offset: 8
samples: 2
speed: 2
z_offset: 1
If I make the following changes (adding ! to PL2)
dir_pin: !PL2
this makes the bed which is already on the bottom go down causing the gears to grind but will eventually move up and allows the bltouch to deploy and complete homing on xyz.
Is there a setting that I am missing that would just allow the print bed and the bltouch to work appropriately with G28 command or will I have to do a home override sequence?
