Totally new to Klipper but can’t seem to find a config file for the Ender 3 Max Neo. Doesn’t seem to exist yet under ‘Configs’ but would someone have one? Should I need to create one, would you recommend the Max or Neo configs as its basis?
Superb! I did see that post but only seen the config for a Max and not the Max Neo edit when I read it again. Many thanks.
Edit: Would it be worth adding this under ‘Configs’? It’s quite difficult to track down, or maybe that’s just me ![]()
I’d suggest you try it out and if you find it working, then post it under the configs section.
