MCU connection issues after update
Printer Model:
MCU / Printerboard:
After updating klipper on my Pi to V0.12, my MCUs were not connecting due to them still being on V0.11, I then recompiled and flashed the firmware for the Octopus MCU, the U2C and the SB2209 MCU, all were successful, and I can see the Otopus MCU when I run lsusb, and the SB2209 reports a UUID when I query the Canbus. All jumpers on boards back to normal, all boards connected as before. Power cycled a couple of times, but I am still getting an Error for unable to connect to EEBCAN when I reboot. Config files are unchanged and all UUIDs and USB serials remained unchanged and can be queried from the PI. What am I still missing to get the SB2209 back online? klippy.log attached.
klippy (1).log (3.7 MB)
Likely your EBBCan is not correctly flashed or connected.
Hi thanks, I will flash it again. But it is currently responding to a canbus query and will display the UUID, so I am not sure if the problem is with the firmware.
Something that bit me during the v11 to v12 upgrade was that I didn’t realize the canboot.bin now compiles to katapult.bin…
The instructions and ‘convenience’ script I usually use in my klipper/canbus rough notes were still referencing the old filename, and mistakenly flashing the old binary to the EBB36 and Octopus :man_facepalming:
This is indeed not an issue. For backwards compatibility, katapult currently compiles both canboot.bin and katapult.bin
Not for me…
Maybe things changed since I upgraded ~wk ago. Pulling, and rebuilding… Now I see both…
Double checking the instructions I normally follow…
Just tested:
klipper@bigtreetech-cb1 ~/katapult $ ll ./out/
total 352K
drwxr-xr-x 5 klipper klipper 4.0K 2024-01-29 19:39:48 .
-rw-r--r-- 1 klipper klipper 4.7K 2024-01-29 19:39:48 canboot.bin
-rw-r--r-- 1 klipper klipper 4.7K 2024-01-29 19:39:48 katapult.bin
-rw-r--r-- 1 klipper klipper  26K 2024-01-29 19:39:48 katapult_payload.c
-rwxr-xr-x 1 klipper klipper 4.7K 2024-01-29 19:39:48 katapult.work
-rwxr-xr-x 1 klipper klipper 186K 2024-01-29 19:39:48 katapult.elf
-rw-r--r-- 1 klipper klipper  66K 2024-01-29 19:39:45 compile_time_request.o
-rw-r--r-- 1 klipper klipper  209 2024-01-29 19:39:45 compile_time_request.d
-rw-r--r-- 1 klipper klipper 2.4K 2024-01-29 19:39:45 compile_time_request.c
-rw-r--r-- 1 klipper klipper 1.1K 2024-01-29 19:39:44 compile_time_request.txt
drwxr-xr-x 4 klipper klipper 4.0K 2024-01-29 19:39:44 src
-rw-r--r-- 1 klipper klipper 5.9K 2024-01-29 19:39:36 autoconf.h
drwxr-xr-x 2 klipper klipper 4.0K 2024-01-29 19:39:24 board-generic
lrwxrwxrwx 1 klipper klipper   34 2024-01-29 19:39:24 board -> /home/klipper/katapult/src/lpc176x
drwxr-xr-x 3 klipper klipper 4.0K 2024-01-29 19:39:24 lib
-rw-r--r-- 1 klipper klipper   27 2024-01-29 19:39:24 board-link
drwxr-xr-x 7 klipper klipper 4.0K 2024-01-29 19:39:24 ..
I’d be surprised that your katapult does something different to mine
I see building legacy canboot.bin has been around for 6mths…
State of my dir must’ve been a result of the instructions/scripts/notes I was following…
Thanks for this! I will try it in the morning and feedback.
You’re welcome, but @Sineos correctly pointed out my theory about canboot.bin not being built was wrong.
Whatever issue(s) I faced during the PITA upgrade was probably due to something else I did wrong. Updated my notes, and will proceed more mindfully during future similar upgrade.
good luck!
I dont know exactly what it was, but following your notes step by step with some slight deviation resolved my issues, so thank you!
