Printer Model: Ender 3 V2
MCU / Printerboard:4.2.2 mainboard
klippy.log (130.0 KB)
HI all, so getting the following error after i have setup canbus with EBB36 and U2C
MCU ‘EBBCan’ shutdown: ADC out of range
This generally occurs when a heater temperature exceeds
its configured min_temp or max_temp.
I am using the basic settings and the temp probe is a stock one from and Creality spider v2 hotend.
Thanks for any and all help
@427theboss
Any reason a thermistor is not plugged into TH0?
Seems he put it into the PT1000 connector or is using this sensor.
hi,
Thanks just figured it out after posting. Everything is working now.
Thanks to those who took the time to respond
Hello @b_white_80 !
The solution is noted on post #1
I have mine plugged in that THO location but I am still getting the same error.
klippy (6).log (2.7 MB)
If you think you have another issue that leads to the error message, then please open a new thread.
This one is marked as solved and should not be used for a new discussion.
