MCU 'EBBCan' shutdown: ADC out of range
Printer Model: Voron 2.4r2
MCU / Printerboard:Octopus v1.1
Host / SBC raspberry pi 4
klippy 3.log (2.6 MB)
…I’ve checked all configuration and connections but cannot get past this error” much ebbcan shutdown arc out of range?
If anyone can advise on a possible solution I would be greatly appreciated
For you have the PT1000 connected to the EBB (in the beginnig of the log it was directly connected to the MCU and caused the same error), you should deeply investigate that part. May try with a different thermistor.
Thanks Eddy for your help. I will try a different thermistor
