MCU 'mcu' shutdown ADC issue
Printer Model: Voron 2.4 350 (Stealthburner Revo)
MCU / Printerboard: Bigtree Tech Octopus
klippy.log (335.4 KB)
New build here and I’ve got an issue that seems heater related upon first startup. Within seconds the system shutdowns and shows the following message in Mainsail:
MCU ‘mcu’ shutdown: ADC out of range
This generally occurs when a heater temperature exceeds
its configured min_temp or max_temp.
Printer is shutdown
I’ve tried a couple different settings for max/min temp but nothing seems to fix the issue. Any help would be appreciated. See attached Klippy file.
