NTC 100K MGB18-104F39050L32 error
Printer Model: Voron 2.4
MCU / Printerboard: BTT octopus
Host / SBC Raspberry PI 3B
Describe your issue: I am building a Voron 2.4 I am having troubles with the thermostat for the hotend. Im not sure if I have it configured right.
the error is
MCU ‘mcu’ shutdown: ADC out of range
Sensor ‘extruder’ temperature -88.522 not in range 0.000:300.000
klippy.log (516.6 KB)
config-20240919-161858.zip (4.1 KB)
See ADC out of range
try this.
sensor_type = Generic 3950
#pullup_resistor = 4700
#inline_resistor = 0
sensor_pin = PF4
if not
make sure you are on the correct port.
