Printer Model: Voron Trident 350 AWD
MCU / Printerboard: Manta MP8 v.2
Host / SBC: BTT CB2
klippy.log:
klippy.log.zip (993.5 KB)
After updating Klipper from v0.13.0-303-gac6f059c to v0.13.0-320 via KIAUH, when booting the printer I got the error: ‘MCU’ object has no attribute ‘_mcu_freq’. I had to roll back the new version to v0.13.0-303 and everything worked again. All of the printer’s MCUs (Manta MCU and EBBCan MCU) are flashed to v0.13.0-303-gac6f059cb. I would appreciate advice on how to solve this problem.
Your log doesn’t show the error as it doesn’t contain any attempt to run Klippy on version v0.13.0-320. That said, most likely the issue is with one of your 3rd party modifications. Its accessing code it shouldn’t which makes it susceptible to errors when the main software changes.
We had a similar report on klipper discord yesterday. It is the cartographer causing the issue and as of yesterday there was no compatible firmware for it.
Quote from the user: ”Update: The latest upate does not work wit cartho at the moment. had to roll back 6 versions after visiting the cartho discord.”
Unfortunately I cant say which commit that actually is.
Hi @AlexTheGreat ,
From the Cartographer Discord:
Yet again breaking changes were pushed to klipper main branch and you will receive the following error
Internal error during connect: 'MCU' object has no attribute '_mcu_freq'
DO. NOT. UPDATE. KLIPPER
(again ..)
if you did
- Option A: use KIAUH to rollback to the first oct or earlier
- Option B: use command line like so:
cd ~/klipper/
sudo systemctl stop klipper
git checkout 35aeb78088f2a5c76c1945266e3458e097dc0c69
sudo systemctl start klipper
My apologies. I replaced the klippy.log file with the one from yesterday.
Hi @AlexTheGreat ,
Cartographer has released a software update that is compatible with the newest Klipper. You can now update Klipper and Cartographer software as usual.
