Mess with axis_twist_compensation documentation
Printer Model: CR-10 Smart (modifyed)
MCU / Printerboard: SKR TUrbo 1.4
Host / SBC: Raspberry Pi 4b
The follow documentation is wrong/incomplete:
The first issue is the documentation don’t tell about the installation proccess. Also, I can’t find the last stable version. I used the 6149 branch to test:
git fetch origin pull/6149/head:x-twist-compensation-simple
After configure all params in printer.cfg, I received the error
calibrate_end_y is not part of [axis_twist_compensation] section.
After remove it, tried again using:
AXIS_TWIST_COMPENSATION_CALIBRATE AUTO=True
But I just see a last update (2 weeks ago) the auto calibration was removed.
Well, not sure if I’m missing something but the documentation is too simple and incomplete and not all describet is working property.
Could someone give some help?
Hello @tiagomaricate !
What installation process?
[axis_twist_compensation] is part of Klipper. There is no need for installation.
If you use a random commit from a random branch you can’t expect the official documentation to match that commit’s behaviour.
There is a proposed change to remove the auto parameter: axis_twist_compensation: remove auto parameter from axis_twist_compensation by yochiwarez · Pull Request #6739 · Klipper3d/klipper · GitHub, but that has not been merged so the published documentation is accurate for the current state of the code. If that PR is merged, the published documentation will update shortly afterward with the changes from that PR.
