Siro
August 23, 2022, 3:24pm
1
I have added following sections to my config file:
[extruder_stepper stepper_ext1]
extruder:
step_pin: PC1
dir_pin: !PC3
enable_pin: !PC7
rotation_distance: 7.65
[tmc2130 stepper_ext1]
cs_pin: PC5
interpolate: True
run_current: .65
hold_current: .2
sense_resistor: 0.110
Although the option is clearly present, following error message is generated: “Error: Option ‘microsteps’ in section ‘stepper_ext1’ must be specified”.
If, however, the TMC2130 section is omitted from the cfg file, no error message is generated.
Any hints? Thanks.
Hello @Siro !
You may add the leading 0 before the periods
Siro
August 23, 2022, 3:57pm
3
Thanks for the suggestion, but no success.
Is your Klipper up to date?
As far as I can remember, in older versions the microsteps had to be defined in the TMC sections when used.
You need to include the full name of the stepper.
[tmc2130 extruder_stepper stepper_ext1]
Siro
August 23, 2022, 5:46pm
6
Thanks @jakep_82 . You are right and I would never have guessed that from the error message. Great advise.
ReXT3D
August 25, 2022, 2:15pm
7
FWIW, the exact same full name requirement applies and the exact same misleading microsteps error message occurs when using [manual_stepper].
