Hi Guys, everything was working well. So i installed Klipperscreen to a Android phone. Now when i restart the system, Moonraker does not start. I have to connect with Putty and do : service moonraker restart, then everything is back to normal , until next restart.
Any idea to fix this ?? Other than complete reinstall…
I’ve actually been having the same problem and haven’t figured out what I did to break it, or how to fix it. I’d love to hear if someone has an easy fix. I installed with KIAUH, in case that matters.
Finally after a backup of my config, i reinstall everything. After all installed then did all updates from Fluidd. All works now. Sorry did not find an easier way.
Thanks for the update. I’m still hoping to avoid that, but we’ll see. There’s a setting in the Moonraker config that sounds promising, but I need to find time to research it… And I’m in the middle of a 24 hour print.
So I found a line in the docs that seems to have worked for me.
pi@klipper-x5sa:~/moonraker/scripts $ ./install-moonraker.sh -f -c /home/pi/klipper_config/moonraker.conf
Obviously, this has to point to your actual config, but I think that’s where it should be for anyone who installed via KIAUH.
Hopefully this will help anyone else for finds this thread. The -f forces it to reinstall the systemd service.
Nice, good to remember. Thanks
