Printer Model: Ender 3 32 Bits board v4.2.2
MCU / Printerboard: STM32F103
Host / SBC : RaspiBerry Pi 3 b v1.2
klippy.log IS Blank, adicionei o Moornak
I configured the Klipper through Kiauh, added the Moonraker, OctoKlipper, and generated the firmware with the Creality board’s microcontroller settings. In this case, it’s a V4.2.2 with STMF103. My Ender 3 is a version 3 with this 32-bit board, and I couldn’t find a direct reference file for it. However, I’m using the printer.cfg from the Ender 3 V2, which has the same board, just for reference and to get the initial connection.
I generated the firmware through the make menu config and updated the board, but I’m not sure if it’s correct, as it doesn’t give any indication that it’s complete. So, I tested and installed the Marlin firmware and then the original Ender firmware, and both installed on the board normally. So, I’m sure the SD card and board are OK.
And yet, I can’t connect the Moonraker to the Klipper.
I would be extremely grateful for your attention.
