Move out of range: 5.000 -20.250 5.000 [0.000]
Printer Model: K1 Max
MCU / Printerboard:GD32F303RET6
Describe your issue: I am getting the following error.
!! {“code”:“key586”,“msg”:“Move out of range: 5.000 -20.250 5.000 [0.000]”, “values”:[5.000, -20.250, 5.000, 0.000]}
klippy (2).zip (3.0 MB)
Hello @Samm_Adamms !
Sorry, but we do not support the K1 because Creality missformed Klipper in a way we can not comprehend.
Hint to your issue:
Please verify the print bed limits and the X/Y offsets of the BLtouch
I am having trouble figuring out the offset and coordinates. Is there anyway you could tell me where issue is? I know you don’t normally do anything for the K1 series, but if its a coordinate issue, wouldn’t the same solution apply. I have looked at a few of the examples, and honestly my brain is not braining right now. I just can’t seem to figure out the solution.
As for this:
[bltouch]
sensor_pin = ^nozzle_mcu: PA9
control_pin = nozzle_mcu: PA8
pin_move_time = 0.500
x_offset = 0.0
y_offset = 25.25
z_offset = 1.925
speed = 10
lift_speed = 20
samples = 3
probe_with_touch_mode = true
samples_result = average
stow_on_each_sample = false
samples_tolerance = 0.1
samples_tolerance_retries = 5
sample_retract_dist = 3
the BLtouch is 25.25 mm in behind the nozzle.
You start the bed mesh at Y=5mm
[bed_mesh]
speed = 150
mesh_min = 5,5
mesh_max = 215,215
probe_count = 5,5
fade_start = 5.0
fade_end = 50.0
so that the BLtouch can reach that point, the nozzle has to go 5mm - 25.25mm = 20.25mm
Thanks for the help
