Persistant move out of range error
Printer Model: K1 MAX
MCU / Printerboard:
Keep getting the below warning when trying to print, restarting klipper and firmware doesnt work
!! {“code”:“key586”,“msg”:“Move out of range: 133.857 296.192 5.000 [0.000]”, “values”:[133.857, 296.192, 5.000, 0.000]}
Unconfirmed 532868.zip (1.6 MB)
…Unconfirmed 555962.cfg (9.8 KB)
Hello @bad_printer !
This is quite hard to tell, because the klippy.log does not adhering to the genuine Klipper conventions.
Thank you for the reply, appreciate you looking into it.
I did manage to solve the issue though. The printer was attemping to move outside the printer movement limits (296.192) i changed the printer limits in the config file to (297) and has resolved the issue
