Multiple Klipper/Moonraker instances
Ender 3S1
CR4NS200141C13 board
Raspberry Pi 3B+
klippy(2).log (59.7 KB)
I am trying to set up several klipper/moonraker instances to connect 2 oder 4 printers to one Rasp Pi, but I don’t get it work.
Is the problem that I try to expand the system from one instance (works perfect) to more instances - is it recommended to start a new installation on a new system instead?
Is the performance of one Rasp Pi 3+ enough for 2 or even 3S1 printers?
To use my old configuration: I assume, just the printer.cfg has to be transferred to the new instances?
Grateful for any help - or a basic description to set up multiple instances.
Doing it manually is quite involved.
I recommend using KIAUH. The only challenge is, that once you have installed one instance, KIAUH does not offer to add additional ones (at least this was the case last time I checked)
So, the probably easiest way is backing up your config folder and start over with KIAUH.
Always keep in mind: If you are running 4 prints and the Pi crashes for what reason ever, all prints are gone.
