Hi!
Would it be possible to create multiple virtual COM ports for Klipper?
Or change default COM port to different path?
I want to get Pallete 3 Pro going with Klipper and I want using RS232 converter on RPI get commands from Palette and put them through to Klipper.
But I want as well web GUI working, which is currently using COM port (Fluidd).
Two COM ports would solve my problem, I would write C# script to transfer data from Virtual to Real COM port and allow Pallete 3 Pro work correctly.
Thank you a lot
