My print is wayyyy too tall
Printer Model: Tevo volcano
MCU / Printerboard: MKS Gen_L v2.1
Host / SBC Pi4
klippy.log attached
klippy.zip (997.2 KB)
I am setting this machine up from scratch.
I have NO details on the parts as it was given to me as-is
I think I have most of it running well.
My first print was a benchy.
X and Y seem pretty good in terms of dimentions
However, this is the tallest Benchy I have ever see.
It’s double or almost tripple the height of a normal benchy.
What did I get wrong?
(If you wouldn’t mind sanity checking my other settings, that would be great too) :wink:
D
Could be helpful to know how much too tall exactly.
You may check on the z-axes:
rotation_distance
microsteps
in comparison to the used hardware/the settings on the board.
Most of them you can do on the hardware:
https://www.klipper3d.org/Config_checks.html
So,
Here is a picture of the benchy next to a proper benchy.
You can see that it’s just the height that is out of wack.
Something I noticed, the layers are very loose, it will just crumble in my hands.
So, it must be something about how it’s stepping I suspect.
I do too.
For you run the steppers in stand-alone-mode, you should check the microstep settings of the z-axes.
Also the thread pitch of the z-axes.
Also see Z axis travel adjust - #10 by Sineos
Just wanted to close the loop and let you all know that it’s working fine now.
I was looking at some other configs and noticed that some specified the TMC driver type and added a section for it. (See below)
Why did adding the tmc2208 section make a difference?
My X and Y are closed loop steppers so on the MB they don’t have driver modules (they are pass throughs since there is a driver board on the motor itself in this case)
Should I add a tmc2208 driver section for X and Y as well or do closed loop steppers not need this?
step_pin: PL3
dir_pin: PL1
enable_pin: !PK0
For TMC2208 at 1/16 microsteps with 400 steps/mm
Don’t use a calibrated value, use the theorical value only otherwise
the TMC2208 may stop working while printing
rotation_distance = <full_steps_per_rotation> * / <steps_per_mm>
rotation_distance = 200 * 16 / 400
rotation_distance: 8
position_max: 300
homing_speed: 8
[tmc2208 stepper_z]
uart_pin: PK3
tx_pin: PL7
run_current: 0.800
Obviously the jumpers for the stand-alone settings of the driver are different.
BTW:
When copy&paste code snippets, please use the Preformatted Text feature of the forum editor to make it look more smooth.
Format
Defining an UART interface for a standalone or externally controlled driver seems very wrong.
