When I define [extruder] sensor_pin as ADC pin of the N32G452 klipper does not start.
I think that this is ADC problem of N32G452, because when I pick one of Manta ADC ports everything works - I can set temperature via mainsail and heater connected do N32G452 board is working (temperature sensor connected do manta)
Sending MCU 'nozzle_mcu' printer configuration...
Transition to shutdown state: MCU 'nozzle_mcu' spontaneous restart
Dumping 11 requests for client 548416608848
Received 7161.450321: b'{"id": 548149630928, "method": "info", "params": {"client_info": {"program": "Moonraker", "version": "v0.9.3-68-gebaa664"}}}'
Reactor garbage collection: (7162.86257636, 0.0, 0.0)
Printer is shutdown
