I have an ender 3 1st Gen with Some modifications. The modifications are as follows.
Raspberry pi (Running Octoprint)
-With original Raspi 2.5 Amp Adapter
BL touch
SKR mini E3 V3
Magnetic bed with PEI coated sheet
High tension (Yellow) springs
Initially i was running Marlin on the stock melzi board. (with a bypass kit for BLtouch). Then i saw some reviews on Klipper. I shifted to Klipper with the same config. First i would like to say that the firmware is friggin awesome, the ease of use is by and large better than any else.
On the stock setup i would keep getting MCU Shutdown Errors. So i thought i would upgrade the mainboard (could only get the SKR mini E3 V3 where i live). But even Then the same error is popping up.
MCU ‘mcu’ shutdown: Not a valid ADC pin
Printer is shutdown
Protocol error connecting to printer
After going through the Log file i understood the ADC part. Since then i have Checked the extruder, the bed but it looks like all the thermistors are working. I even disconnected and reconnected all the wires. But no dice.
Please guide me on how to solve this. Im not a programmer and my skills with computers are OK.
Thx.
klippy.log (53.6 KB)
