N32G455 ADC restart
Printer Model: EasyThreed X4 Plus
MCU / Printerboard: MKS Robin mini 2.0
klippy.log (20.4 KB)
Has anyone been able to flash the firmware for the N32G455 and use the ADC pins (in my case, PC0 and PA0) for temperature measurement? I flashed the firmware for this chip, but when I try to measure the temperatures, the printer crashes and restarts, and it won’t connect to the clipper.
Hi @marroquin02 ,
This is an English-speaking forum. Please use English for future posts (feel free to use an online translator if needed).
According to Google Translate, your first post is:
Has anyone successfully flashed the firmware for the N32G455 and been able to use the ADC pins (in my case, PC0, PA0) for temperature measurement?
I flashed the firmware for this chip, but when I try to measure the temperatures, the printer crashes, restarts, and doesn’t connect to Klipper.
Looking at your klippy.log, there’s no ADC errors present, just cannot update MCU as it is shutdown. Please upload a new klippy.log with the ADC error present.
This is the new registry entry; I’ve also attached the Printer.cfg file.
Welcome marroquin02,
No need for “https://pastebin.com”, just attach the file here.
klippy (3).log (41.6 KB)
Sorry, the file is attached.
MKS has this: Klipper-for-MKS-Boards/MKS Robin Mini V2.x/generic-mks-robin-mini-v2.cfg at main · makerbase-mks/Klipper-for-MKS-Boards · GitHub
Apparently predates Klipper V0.12 as it says to compile for STMf103.
Only other thing I find is this: Nations MCU support/flashing
