New Monster 8 MCU error during connect
Printer Model: Voron 2.4
MCU / Printerboard: MKS Monster 8
klippy.log (13.2 KB)
I recently updated from a spyder 2.2 to a Monster 8 and having a number of issues connecting and such. I use a Mint Linux control mini PC and can’t quite seem to get connected to the printer. It flashed perfectly and I tried it several times and now have a steady stream of log files that indicate mcu shutdown and I can ls -l /dev/serial/by-id/* and it returns a value as well as by-path. Just not sure what I am missing here.
Your log does not contain much except Can not update MCU '<name>' config as it is shutdown
I really don’t have much to go on beyond that. I am sure you can imagine how many restarts I have gone through.
It sees the damn thing.
[ 2.174383] usb 1-4: New USB device found, idVendor=1d50, idProduct=614e, bcdDevice= 1.00
[ 2.174399] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.174405] usb 1-4: Product: stm32f407xx
[ 2.174409] usb 1-4: Manufacturer: Klipper
[ 2.174413] usb 1-4: SerialNumber: 470042000D50315141323320
/dev/serial/by-id/usb-Klipper_stm32f407xx_470042000D50315141323320-if00
OK progressing after a reflash. I named the file mks_monster8.bin as I saw in another post and restarted.
New log attached. I am thinking I have to get more info on the thermistor defs.
klippy.log (44.9 KB)
The various NTC variants as listed here do not play a big role. Such an error typically points to a wiring issue or dead thermistor.
grafik
It’s your bed’s sensor that is acting up.
Awesome! I’ll give it a look see. Thanks and will update.
Not sure where I see an error for it this time…target and reading for bed temp are now zeroed out anyway.
klippy.log (49.3 KB)
I have kept at editing and am not seeing any errors but still nothing connects and I am just not sure what is happening. It looks like it hangs but continues to receive data from the MCU just fine but nothing in Mainsail.
klippy.log (8.7 KB)
Now that I got a clean log indicating startup I figured something else was up so I removed everything with kiauh and reinstalled and viola it’s working. now some tuning and hopefully all will return to normal.
Thanks for the input!
