No camera in Mainsail, but works from Pi just fine?
Printer Model: Creality Ender 3
MCU / Printerboard: BTT SKR Mini E3 -v- 3.0
Host / SBC: Raspberry Pi 4B, 2GB
klippy.log (13.5 KB)
Don’t understand this… in Mainsail, all I get from the raspicam is “No signal.” However, if I directly access the RasPi4 with a keyboard and display attached directly to the card, and I enter “libcamera-hello,” I get about five seconds of video, then it cuts out and leaves the following lines:
karl@mainsail:~ $ libcamera-hello
Made DRM preview window
[0:12:23.608590019] [3747] INFO Camera camera_manager.cpp:297 libcamera v0.0.5+83-bde9b04f
[0:12:23.637574982] [3748] WARN RPI vc4.cpp:383 Mismatch between Unicam and CamHelper for embedded data usage!
[0:12:23.638366091] [3748] INFO RPI vc4.cpp:437 Registered camera /base/soc/i2c0mux/i2c@1/imx219@10 to Unicam device /dev/media1 and ISP device /dev/media3
[0:12:23.638417665] [3748] INFO RPI pipeline_base.cpp:1101 Using configuration file ‘/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml’
[0:12:23.639299736] [3747] INFO Camera camera.cpp:1033 configuring streams: (0) 1640x1232-YUV420
[0:12:23.639814383] [3748] INFO RPI vc4.cpp:565 Sensor: /base/soc/i2c0mux/i2c@1/imx219@10 - Selected sensor format: 1640x1232-SBGGR10_1X10 - Selected unicam format: 1640x1232-pBAA
I’m guessing I don’t have the crowsnest.conf file set up with accurate information… what’s in it now doesn’t match with the output of the RasPi from the “libcamera-hello” command. Do I need to take the information from the Pi output and plug it into the crowsnest.conf file and do a software reboot? Attaching the crowsnest.config.
crowsnest.conf (2.0 KB)
Thanks in advance!!
Host / SBC: Raspberry Pi 4B (2GB)
Don’t understand this… in Mainsail, all I get from the Raspberry Pi camera is “No signal.” However, if I directly access the RasPi4 with a keyboard and display attached directly to the card, and I enter “libcamera-hello,” I get about five seconds of video, then it cuts out and leaves the following lines:
Thanks in advance!!
Note: this post was previously and mistakenly placed in the “Frontends” category, and I’ve no idea how to move it (or if I even can move it), so apologies for the same topic double-post.
Please don’t multiply your threads.
For it refers to camera stuff, it belongs to frontends, in your case to Mainsail.
Apologies for the duplicate… I didn’t realize camera issues went into Front End, though in retrospect that makes sense.
