No XYZ movement
Basic Information: Replaced Motherboard and Hotbed
Printer Model: Ender 3 Max Neo
MCU / Printerboard: V4.2.7
klippy.zip (977.2 KB)
NO XYZ motion on my Printer. I installed new Motherboard and Hotbed. I can control the heat for the Hotbed and the Hotend, but get errors like this "
{“code”:“key22”, “msg”:“No trigger on x after full movement”, “values”: [“x”]}".
Sorry, this is just the printer.cfg, not the klippy.log.
Please attach it to your next post.
Ok, grabbed the wrong file. This should be correct.
Could it be that you run Klipper on some exclusive hardware, like Sonic Pad?
Yes, I do run Klipper on a Sonic Pad. I’m getting the feeling this is not a good idea. However, I feel the lack of movement might be more to do with the connection to the Motherboard
can you check your cable’s of your endstops specialy the x.
A another solution can be instal the orginele firmware without the sonic pad
Checked my cables and they all seem to be connected.
but now I get a Klipper error as it is not loading.
