Not able to communicate with adxl345 anymore
Printer Model: Voron 2.4
(I dont see how to attach the klippy.log - there is no attach function)
I have been strugling with a weird situation the last couple of weeks
A while ago I ordered 4 ADXL345 accelorometers on amazon.
I mounted one of them while looking in the docs for klipper.
I mounted it all correct and got it all up working. (query responded correct)
I did a full ressonance test and entered the values into my printer config.
(manually reading the graf’s)
Then after a week or so I wanted to test the SHAPER_CALIBRATE command and that also worked fine..and it worked perfectly by using safe_config.
I then decided to draw a longer wire so I could keep the ADXL fixed on the toolhead.
After mounting a new ADXL to the new fixed wire I keep getting
“Invalid adxl345 id (got 0 vs e5)”
I have tried using the old wire + 3 other wires. Short and longer.
I have tested with 3 different copies of the same ADXL345 board.
I had some of the mainsail/klipper modules that updated after I made the first install, but I am not sure if they updated before or after it started being buggy.
I also tried using a pico instead of my pi as secondary mcu.
Still same error.
klippy.log (863.2 KB)
or simply drag and drop. Zip if too large
You could try this ADXL345 Connection Help! - #4 by Sineos
Good luck, hcet14
