Unable to communicate with ADXL345
Printer Model: Custom CoreXY
MCU / Printerboard: Manta M8P/EBB42
klippy.log (757.8 KB)
After replacing an Octopus V1.1 with a Manta M8P (with CM4 Host and CAN connection to an EBB42 toolhead controller) with a new rPi OS build, I decided to try to do SHAPER_CALIBRATE which didn’t work.
I did follow Measuring Resonances - Klipper documentation and everything seemed to go swimmingly.
When trying to test the connection I got the Failed to import 'numpy' module,... for which I applied the @oldab fix found here:
Which resolved the numpy import failure but now when I try to do an ACCELEROMETER_QUERY, I get:
You’ll note that I did it twice (a lot more actually) as there are comments saying that multiple ACCELEROMETER_QUERY requests may be required to cause the ADXL345 initialized.
I have had the ADXL345 working before - but I fear that was back in the Python 2.x days.
Any ideas what I should try here?
I hope I’m right and you just mixed up the MISO/MOSI pins:
[adxl345]
cs_pin = toolhead:TOOLHEAD_ADXLCS
spi_software_sclk_pin = toolhead:TOOLHEAD_ADXLSCLK
spi_software_mosi_pin = toolhead:TOOLHEAD_ADXLMISO  <<
spi_software_miso_pin = toolhead:TOOLHEAD_ADXLMOSI  <<
axes_map = x,y,z
That was it. I swapped the two lines and:
I’m going to have words with the guy who made the printer.cfg changes. :wink:
You’re the man!
Glad I could help!
