Printer Model: Ender 3 Belt printer
MCU / Printerboard: SKR Mini E3 V3.0
Host / SBC Raspberry Pi
klippy.log N/A
Heya, as listed above I have an Ender 3 45degree belt kit w an SKR Mini E3 V3.0.
Had a very hard time finding any help on the config, finally was able to cobble one together.
I would like to submit it for the examples, since I wasn’t able to find one and the site pushes the SKR Mini as one of the upgrades. I’m sure others have or will be looking for one.
Please advise.
Thanks in advance.
Bart
Klipper E3 belt kit w SKR Mini E3 V3.0
Looks like your config is doubled up, you have two of each stepper defined with the exact same name.
Looks like you copy and pasted twice honestly.
I’d also remove all the mainsail/fluidd sections you have commented out. They should be included with those installations by default (if I remember correctly) so you don’t need them as a base config file for others.
That’s what I noticed off hand, You might not have any but I’d try not to include any custom GCode macros except for ones needed for that specific printer.
The one to remove parts from the bed is a good one to keep, because that’s needed for that printer.
