Nozzle too high even after manual levelling. Help
Printer Model: Ender 5 plus, mostly stock, microswiss and direct drive mod.
MCU / Printerboard: Creality V2.2
Host / SBC Raspi 3B+ Mainsail OS
klippy(1).zip (401.0 KB)
Hello.
I have installed Klipper into an Ender 5 Plus. I had to install a modified Klipper (Desuuuu fork) to be able to use the screen.
I flashed the board, the screen, and installed Klipper onto the Pi. Everything is updated through Kiauh.
I can generally do everything.
I have manually leveled the bed, but when I send out a print, the nozzle stays about 3-4mm from the bed.
I have been looking everywhere, and see nothing.
I have tried to disable the BL Touch, but it throws an error about
or
Unknown pin chip name probe
I have tried [stepper_z] position_min:-2,-4, -6
Any and all help will be greatly appreciated
Hello @Elucubra !
Have you done a SAVE_CONFIG after that?
Yes. I will try again though. I’m considering reinstalling the whole thing. I really don’t want to go back to Marlin.
No. I must have not saved somewhere. I repeated the whole probe_calibrate and saved. Worked. Thanks!!
