This macro performs a back-and-forth wipe of the nozzle along the X-axis of a Cartesian bed-slinger. The brush is attached to the X-gantry outside of the normal bed range. So, the X-axis position_max value must be increased in the PRINTER.CFG file to allow the nozzle to move to the brush.
VARIABLES:
- wipe_count: pretty much self-explanatory just know that each count represents a wipe in one-direction only. Back-and-forth is two wipes.
- y_dir [-1 | 0 | 1]: If nozzle is near Y edges of bed where it could interfere with bed clips then 10mm will be subtracted | omitted | added to the Y position.
PRINTER.CFG file:
Revise [stepper_x] section
position_max: 255 # this value is peculiar to my printer which is normally 220. Yours will certainly be different.
Add the following macro:
[gcode_macro CLEAN_NOZZLE]
description: Simple X-axis back and forth nozzle wipe performed wipe_count/2 times. Two PARAMETERS are both optional. The LAYER parameter provides the current layer info from your slicer's Layer Change G-code and CLEAN_LAYERS provides the iteration control for how frequently the nozzle procedure is actually performed. Defaults to 1, i.e., every layer. E.g. , CLEAN_NOZZLE LAYER={[layer_num] CLEAN_LAYERS=3 will clean the nozzle every third layer. Omitting the parameters forces the clean to be performed. While wipe_count could be changed to a parameter, once you determine how many wipes are sufficient it's simpler to set its value within the macro and fuhgetaboutit.
{% set layer = params.LAYER|default(0)|int %}; active layer number
{% set clean_layers = params.CLEAN_LAYERS|default(1)|int %}; perform clean procedure every X layer
{% if layer%clean_layers == 0 %} #the percent sign performs a modulo math operation, i.e., it calcs the remainder of a division operation
SAVE_GCODE_STATE NAME=clean_nozzle_state
{% set wipe_count = 6|int %} # each count is a wipe in one-direction
{% set y_dir = 0|int %}
{% if printer.toolhead.position.y > (printer.toolhead.axis_maximum.y - 10) %}: # check for potential nozzle movement interference with bed's edge retaining clips
{% set y_dir = -1 %}
{% elif printer.toolhead.position.y < (printer.toolhead.axis_minimum.y + 10) %}
{% set y_dir = 1 %}
G91
G0 Z5 # avoid potential nozzle drag across existing print
G90
G0 Y{printer.toolhead.position.y|int + 10 * y_dir} # move nozzle away from edge clips
{% for wipe in range(wipe_count) %} # simple X-axis back-and-forth wipe
G0 X{235 + (20 * (loop.index is even))}
{% endfor %}
RESTORE_GCODE_STATE NAME=clean_nozzle_state MOVE=1
Add to your slicer’s Layer Change G-code section:
CLEAN_NOZZLE LAYER={[layer_num] CLEAN_LAYERS=3 will clean the nozzle every third layer. Omitting the parameters forces the clean to be performed on each layer.
Add to your slicer’s End G-code section:
CLEAN_NOZZLE
Brush Holder model can be DL’d from Printables.
