Printer Model: Custom
MCU / Printerboard: skr 1.4 turbo
Rpi 4b with Fluidd
klippy (1).log (2.3 MB)
Hi, i’m working on a brush, on the side of the bed, i’ve created the macro and it work well.
But when i insert the macro on the start gcode, the print process start, but when it’s the time to brush i got this error.
!! Move out of range: -13.041 120.00 0.072 [0.000]
I tried also to put G91 at the start of the wipe macro and G90 at the ending of the macro, i got the same error but coordinates change.
If i start the macro not in a print it works, but while printing it fail, and printing doesn’t continue.
My x min is -12.80, the endstop is outside the bed, and the nozzle have a lot of space between the bed and the endstop when is homed.
I put the brush on the side of the right side of the bed.
Why if i give x-12.70 and my x_min is -12.80 i got this strange coordinates and value?
This is the macro
[gcode_macro WIPE]
G1 X-12.70 Y120 Z0 F9000 ;Wipe 1
G1 X11.20 Y80 Z0 F9000 ;Wipe 2
G1 X-12.70 Y120 Z0 F9000 ;Wipe 3
G1 X11.20 Y80 Z0 F9000 ;Wipe 4
G1 X-12.70 Y120 Z0 F9000 ;Wipe 5
G1 X11.20 Y80 Z0 F9000 ;Wipe 6
G1 X-12.70 Y120 Z0 F9000 ;Wipe 7
G1 X11.20 Y80 Z0 F9000 ;Wipe 8
G1 X-12.70 Y120 Z0 F9000 ;Wipe 9
G1 X11.20 Y80 Z0 F9000 ;Wipe 10
G1 X-12.70 Y120 Z0 F9000 ;Wipe 11
G1 X11.20 Y80 Z0 F9000 ;Wipe 12
G1 X11.20 Y80 Z5 F9000 ;Raise to clear brush
and this one is the start
[gcode_macro START_PRINT_ADAPTIVE_PURGE]
status_Preparing
SKEW_PROFILE LOAD=CaliFlower
G90 ; Set all axes to absolute
M82; set extruder to absolute
G21; Set all in mm
G28 ;Home
M140 S{params.BED_TEMP}; #set bed temperature
M190 S{params.BED_TEMP}; #wait bed temperature
status_Meshing
BED_MESH_CALIBRATE ADAPTIVE=1;
status_Preparing
M104 S{params.EXTRUDER_TEMP}; #set extruder temperature
Smart_Park
M109 S{params.EXTRUDER_TEMP}; #wait extruder temperature
WIPE
LINE_PURGE
G92 E0;
status_Printing
for understanding my start gcode:
Status_printing
Status_Preparing
Status_Meshing
Are macro for led
Smart_Park
LINE_PURGE
Are the macro from KAMP, i use it only for purging near the print.
Thanks in advice!
