I have a start_print macro that is causing a move out of range error when executed in the beginning of a print but not when it’s executed on it’s own. I also preheated the printer manually, ran the macro, and then started the print with the macro commented out. that worked fine.
here is the macro:
[gcode_macro start_print]
conf_runout
SAVE_GCODE_STATE NAME=start_print_state
{% set initialExtruder = printer.toolhead.extruder %}
G28 ; home all axes
G90
{% if printer.extruder.target >= 170 %}
T0
G1 X15 Y145 Z0.2 F15000 ; move to prime
M83
G92 E0 ; reset extrusion distance
G1 X110 E15 F1000 ; prime nozzle
G1 X200 F300000 ; quick wipe
PARK_extruder
{% if printer.extruder1.target >= 170 %}
T1
G1 X15 Y146 Z0.2 F15000 ; move to prime
M83
PARK_extruder1
{% if initialExtruder == "extruder1" %}
T1
{% else %}
T0
RESTORE_GCODE_STATE NAME=start_print_state
description: Home and Prime
here is the gcode I’m trying to print:
here is my klippy.log:
here is the error message I’m getting (and the surrounding terminal echos for reference):
// shaper_type_x:ei shaper_type_y:mzv shaper_freq_x:48.200 shaper_freq_y:32.200 damping_ratio_x:0.100000 damping_ratio_y:0.100000
21:22:07
// Activating extruder extruder1
21:22:07
// shaper_type_x:mzv shaper_type_y:mzv shaper_freq_x:55.600 shaper_freq_y:31.000 damping_ratio_x:0.100000 damping_ratio_y:0.100000
21:22:07
!! Move out of range: 10.000 146.000 0.200 [29.996]
21:22:07
can someone tell me how to get this to work the way I want it to?
