Start-Print Macro Error
Printer Model: Longer LK5 Pro
MCU / Printerboard: atmega2650
klippy_08192023_2039.log (3.2 KB)
start_print.cfg (839 Bytes)
Hello all. I am in need of a little help with an error I keep receiving. I am new to klipper and fairly new to programming languages, so I took a bunch of information from various sources and managed to hodgepodge my start-print.cfg together. Initially, the file was written using NeoVIM along with an end-print.cfg and I have had trouble with klipper not liking something in my file. The issues with the end-print were quickly resolved (always helps to add gcode: after the macro naming line lol), however I am not getting so lucky with the start-print. After issuing a service restart command, I get the following error status on the webGUI on mainsail:
Error loading template ‘gcode_macro start_print:gcode’: jinja2.exceptions.TemplateSyntaxError: expected token ‘end of statement block’, got ‘=’
I am not sure what exactly I am looking for on this. I have (insert number here)checked the file and cannot find anywhere that I have left open a block. Only thing I question is line 25-31 with the purge line if statement. Did I do something wrong with including multiple expressions in an if statement block? Thank you very much for any help that can get me pointed in the right direction! 73’s all!
{% if CURRENTHOTENDTEMP = HOTENDTEMP %}
Should be:
{% if CURRENTHOTENDTEMP == HOTENDTEMP %}
Thank you so much for your help! That, along with making sure the endif ended with %} instead of just a curly bracket, got my macro up and running! I really appreciate your help!
Hello John, I have the same printer of yourse and I start form very shot time to use klipper and I have a lot of problem for setting start and end macro, your printer have a BL-touch? Can I ask you some questions about settings??
Thnks
