Option 'on_error_gcode' is not valid in section 'virtual_sdcard'
Printer Model: ender 3
MCU / Printerboard:atmega1284p
klippy.log (190.9 KB)
after updating klipper and fluidd i wasnt able to connect to the mcu, tried to reflash using kiauh but again no mcu found, after some attemp i tried to reopen the web interface and saw the error message “Option ‘on_error_gcode’ is not valid in section ‘virtual_sdcard’”
tried to reinstale klipper, moonraker and fluidd and the error still there.
i wasnt able to edit the fluidd file section becuse its read only mode.
any one got any advice on how to address this issue?
Have you tried with commenting out that line?
the line is in both the printer and fluidd config, i tried to remove the line in the printer config but the error didnt go away, and i cant edit the fluidd config becuse its in read only mood and i didnt found how to change that
You have the macro [virtual_sdcard] in two configs?
yes, in printer and in fluidd.
but evrething was until i updated klipper and fluidd
Does that make sense?
im not sure, the fluidd config is not somthing that im able to edit and the printer config is a pre made config i didnt wrote myself
