Unable to open config file /home/pi/printer_data/config/fluidd.cfg
Printer Model: Qidi plus 4
MCU / Printerboard: [mcu]
serial: /dev/ttyS2
restart_method: command
baud:500000
[mcu U_1]
serial: /dev/ttyS0
baud:500000
klippy.log klippy.log (3.1 KB)
Hi, I am new to klipper and raspberry pi, I am using kiauh to help install klipper. I keep getting this error and I am not sure how to solve this. When I go to try and find it on my pi, it says it does not exist. I tried looking for solutions and have to find one. Please help, I am a newbie and trying to learn as I go.
See GitHub - fluidd-core/fluidd-config: Fluidd base configuration for Klipper
These are settings needed for the proper functioning of the web interfaces. Depending on your installation process, they may not be automatically installed. For details on what this entails and how to install, see GitHub - fluidd-core/fluidd-config: Fluidd base configuration for Klipper.
I started all over again including following the instructions on the link you provided and have the error: “Include file ‘/home/pi/printer_data/config/plr.cfg’ does not exist” I understand that this does not exist but I cannot find where this file is written in my setup so I can either remove it or if i need to create the file, what does the file need to include. I attempted to make this file originally which is when I got the “unable to open config file /home/pi/printer_data/config/fluidd.cfg”
