When you toggle the pin high, Klipper will instruct the MCU to toggle the respective pin to its high state. What “high” means is up to the board and also how clear the “high” is up to the hardware.
Typically the pins of the printer boards are 3V3, so high should be around 3V3. If you need 5V then you would need to use a level shifter.
I guess it would be best to ask in a community that is dedicated to electronics. Klipper just toggles the pin high. What your board makes out of it, is entirely up to the board’s hardware.
