Printer Model: Elegoo Neptune 4 Pro (with opennept4une installed)
Orca slicer 2.2.0
klippy.log (3.1 MB)
Hi!
I have this issue where no matter what I have done in calibration way, it whont change the outcome.
I can set the PA value on 0.02-0.07-0.56 even 1.0 no diffrence. Every time I do the PA pattern it is 0.06-0.07. simular result with tower.
I have changed this value across the board. (meaning in config file, slicer, advance tab etc all 3 places had same value) The start gcode in slicer. I got suggested once to delete the start gcode of PA in slicers advance tab cause he experience when the gcode get crazy with slicer setting and config setting and somehow mix it up and sloved the issue but deleting that start gcode from klipper. Only thing I notice was that the value is correct in the UI of fluidd. (openneptune version of UI)
Flowrate I have changed but no matter what value it is, it act as it where overflow. 0.30 to 0.95. But do see less extruded but ”over extruded when its less extruded”. really hard to explain what I mean by that but hope you get it.
Jerk, 5mm or 20mm made no diffrence no matter what.
Rotation distance is made over 5-7 times with same result.
Know many don’t like the cube but still good indication on what it might be. You can prob find other stuff thats wrong but my main concern is PA and Flowrate I never get to work. If thats the issue maybe it is something else I cant see.
Have you guys any suggestion? I really hope I can with your guys help, find a solution casue I whant to love this printer but I can´t when it can´t print as it should do nor what it is capable of.
