PA value at the start of printing
Printer Model : VORON 2.4 (DIY
MCU / Printerboard : MONSTER 8 V2
Host / SBC :RAS.Pİ 4
klippy.log :
klippy (1).zip (1.1 MB)
I wanted to consult you. orca sends the PA value as zero in the part I send to the printer from the slicer… or is it just me. (extruder section passure advange section in the printer.cfg file is closed… I use the pa value from the slicer) I would like your comments.
Have you tried .zip or .7z? .zip is valid, .7z not.
I use winrar …
I apologize, I’ll try zip immediately… rar extension may be incompatible
thank you EddyMI3D uploaded as zip. correcting my first post
Make sure to have:
  • Klipper as gcode flavor activated in Orca
  • The respective PA value set in the filament’s properties in Orca
Slice a file and open it in an editor, and you will find the PA settings among the first lines after the thumbnail.
I found the source of the problem . I activated the “Small area flow” feature that comes as a beta feature in orca slicer. Since there are no values in this area, it sends the PA value as 0 again on the specified PA value.
As a result; Thank you to all friends who helped.
