(To answer my question the Duet Wifi pictured below is an earlier version of the Duet 2 Wifi with the same pinout as the current Duet 2 Wifi. They changed the name when the ethernet version came out after version 1.05)
Hello All, I am looking for a pinout chart for the DuetWifi pictured below it may also be know as the Duet 2nd Gen but not the Duet(2). Can any one point me in the right direction?
I did find a pinout for the Duet2wifi at the below address. Can anyone let me know if the pinouts are the same for this and the older DuetWifi pinout I am looking for.
Thank you for replying, the reprap link you provided is where I got the photo above. I am looking for a pinout that I can use to build a config.cfg file.
i. e. the location of the stepper pins below and all the other pins on the board. I provided an example from the Duet web site of what I am looking for above. But that one is for the Duet 2 Wifi.
