Printer Model: Ender 3 s1
MCU / Printerboard: Creality 4.2.7
Hi guys. I recently had a problem while using the exclude_object script.
I was calibrating my flow by printing multiple squares in a single gcode file. If none of the squares was excluded during the print, every squares were printed correctly. But whenever I excluded all the squares but the one I was doing tests on, that square was printed with a problem, a gape near the outer wall. On the pic, both squares are the same square from that Gcode, left one when no objects are excluded, on the right that same place square when all the other squares are excluded. I tried multiple times with that same gcode, but also with another Gcode with these same squares. And again with that other Gcode, I had no problem when no objects were excluded.
I did some more tests : The Gcode file is 6 identical squares near to each others. When I print them all without excluding any, they all print fine. But when I leave only one and exclude the rest, 3 of the squares print like the right square on the picture, one is printing fine despite being alone, and the 2 other squares are not even printing a correct 1st layer, so I have to cancel the print as the outer walls are not even sticking on the bed.
Any idea about what is happening ?
Thanks.
klippy.log (1.1 MB)
