Pressure Advance calibration error
Printer Model: Creality Sermoon D1
MCU / Printerboard: STM32F103.
Host / SBC: armv7l, 32bit
Hi all,
I am new to Klipper and i am having some trouble with the pressure advance calibration. I am following the official Klipper documentation for Pressure Advance calibration.
However, when using OrcaSlicer’s Pressure Advance Test Tower or PA Calibration Pattern, the print fails immediately with the following error:
Error on ‘SET_PRESSURE_ADVANCE ADVANCE=-0.002750000’:
ADVANCE must have minimum of 0.0
Important details:
  • I am not manually setting any negative PA values
  • In OrcaSlicer, the PA calibration range is explicitly limited to start = 0
  • The same error occurs with both PA test tower and PA pattern
  • The error happens before printing starts
  • The issue is reproducible every time
All suggestions are appreciated. Thanks in advance.
klippy (1).log (8.1 MB)
Hi @LTG ,
Can you please upload the G-code you’re trying to print?
