Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
I’ve searched imho everywhere but I didn’t find anything besides ai slop or topics relating to PAUSE - sorry if I missed it.
My printer bed is on 3 T8 rods and will drop a bit when the steppers are turned off, forcing a new G28 Z0 and a Z-TILT every time. I’d like it to keep the Z-steppers on and maybe, if possible, kill them after idle-timeout.
Is there a way to disable turning off the Z-stepper after a print? It feels stupid that i didn’t find anything on this, sorry…
Usually this is either set in the Slicer end gcode script settings or the END_PRINT macro in Klipper - hence the need of the klippy.log as @cardoc explained.
END_PRINT:
\[gcode_macro END_PRINT\]
G91 ;releative positioning
G1 E-1 F2700 ;Retract a bit
G1 E-1 Z0.2 F2400 ;Retract and raise Z
G1 X-3 Y-3 F3000 ;Wipe out
G1 Z10 F400 ;Raise Z more
\# Turn off bed, extruder, and fan
M140 S0
M104 S0
M106 S0
G90 ; Absolute Positioning
G1 X150 Y20 F3600 ; Move Printer Head Out of Way
M84 X Y E ;Disable all steppers but Z
SET_STEPPER_ENABLE STEPPER=stepper_z ENABLE=1
I already added the last line to enable Z again but no go.
well that did it. I somehow didn’t notice the M84 (or what it does), thinking the “steppers-off” was somehow hardcoded or something. Wrong, ofc.
Solution for me: I’ve added the following to my END_PRINT:
# M84 X Y E ;Disable all steppers but Z
SET_STEPPER_ENABLE STEPPER=stepper_x ENABLE=0
SET_STEPPER_ENABLE STEPPER=stepper_y ENABLE=0
SET_IDLE_TIMEOUT TIMEOUT=1800
Beware that if you use SET_STEPPER_ENABLE to disable a motor, klipper does NOT remove that motor from the list of homed axes. It will still allow moves on that axis and act as if the position for that motor is known.
If your machine is a coreXY, disabling one of x or y allows movement on both axes, and both could move out of position, but klipper will act as if they aren’t. So make sure you re-home before doing any movements.
